C/C distance on a 80+ liquifires
Grumpy
Post by Grumpy »
Anyone know what the C/C distance is on the crank to jack shaft on a newer Liquifire?
Is there a differance on the C/C distance on the Liquifires with the TR800 clutches?
Are the belts longer on the sleds with the TR800's?
What would be the easiest way to figure out a belt length on a sled with a 12-1/2" C/C distance using say a Comet 102C & a Polaris P85 driven using a belt width of 1-3/8" or a little wider if someone produces one wider??
Grumpy
Do War Protesters have reunions? IF So, What do they talk about??
Re: C/C distance on a 80+ liquifires
You may be able to use this online calculator if you could figure out the inner diameter of the primary clutch in the open position.
http://www.calculatoredge.com/mech/vbelt%20length.htm
lwb140
Real Name: Wade bennett
Post by lwb140 »
grumpy our 80 cc sled has a p85 with a team secondary , it has a napa 38x4725 on it I believe it means 1 3/8 x 47 1/4 id think it would be similar to the set up you described wade
Grumpy
Post by Grumpy »
Wade could you get me the C/C distance between the two clutches on your 80 CC Liquifire? I don't seem to have one available where I'm at.... I'm needing a 12.5" C/C
Thanks Harley I'll check on that when I get back & can get my mesurements correct.
Wade, the 83 FT Manual doesn't give a mesuremant for the Liquifires because the C/C distance isn't adjustable on the newer ones
Grumpy
S_Kyle
Real Name: Scott Kyle
Post by S_Kyle »
I was looking in my fine tune manual and stumbled across these measurements.
80-83 liquifires
102c 11.88" +/- .030"
TR 800 11.88" +/- .030"
Grumpy
Post by Grumpy »
Huh, I looked in there & didn't find that info, thanks for spotting it for me..
I was afraid of that, thats still over 1/2" shorter than what I need.
The project I'm working on has a 12.5" C/C distance..
Thanks for the info... I'll have to look at other brands
Grumpy
