mikuni swap?
KamJD600
Real Name: kameron peck
mikuni swap?
Post by KamJD600 »
i would like too put a mikuni on my 75 600 but whare would i get a carb flang, what size carb would i need(jetting?), throttle/choke cables? whare would the best place to get it all? :letitsnow:
kameron
Re: mikuni swap?
I bet you will find all that and more at New Breed Parts. There is a link to the site on the home page of JDSleds.com.
You will need a trottle grip from a Cyclone/L-Fire(1st generation) to accomedate the extra cable travel required on a Mikuni.
Post a wanted ad in the classifides and someone will offer you a good used one.
Re: mikuni swap?
Carb: http://www.newbreedparts.com/newbreed/i ... earch=vm34
Fuel Pump: http://newbreedparts.com/newbreed/index ... uct_id=135
Carb Mount: http://newbreedparts.com/newbreed/index ... duct_id=90
Throttle Cable: http://newbreedparts.com/newbreed/index ... uct_id=122
Choke Cable: http://newbreedparts.com/newbreed/index ... uct_id=131
I can get you the correct jets too but we would need to pick a starting point. Maybe go off a 440 Cyclone specs? It will require some tuning on your end.
KamJD600
Re: mikuni swap?
Post by KamJD600 »
Thank you guys. the tuning shouldn't be an issue. I just didn't know are to start. I'll be in contact with you Matt soon
