What is the most powerful sled john deer came out with
Danzig
Real Name: Paul File
Re: What is the most powerful sled john deer came out with
Post by Danzig »
I reduced pilots due to this problem, I think I went from 35 to 30 or 40 to 35..... :doh:
Danzig
Post by Danzig »
also...that CDI may be getting heat soaked and then ..... :bonk: :bonk: :bonk: .................. :boohoo: .................. :brrr:
vader
Post by vader »
I replaced cdi. I think I am going to look at pilots another guy said the same thing. Can't wait to get back on snowed for four days here. Perfect conditions for sledding. Is a jdx8 a 400cc?
vader
Post by vader »
Here is my ifs. I have a few little bugs to work out. But it works
vader
Post by vader »
How wide is the clutch belt suppose to be new. I got people telling me 1.250. The manual says 1.375" new however the belts they are selling me is #1105 and 1.250 thick. I think it is wrong
TASKY
Post by TASKY »
Thats one big turbo diesel in the background. I like your sled.
If that '82 has the OEM secondary, the belt width new is supposed to be 1-3/8". The JDX8 had a 440cc engine.
liquitisplit80
Real Name: Roy
Post by liquitisplit80 »
OK, while we're on the topic of engine temps for liquifires, I have an 81 LF that no longer has the original temp gauge, it is the graduating numbers style. My question is on the original gauge, what is the temp range of 'normal' (in the black) and what is the temperature when it reaches the red zone on the original gauge. I want to be able to convert this over to the new gauge and have confidence I'm not overheating. New gauge is a Sunpro and starts at 100 and goes up to 250 degrees.
'78 Spitfire
82 Trailfire 340
'80 Trailfire 440
'80 sportfire
'81 liquifire
Still ridin' the New Breed!
The Fire Series Liquifires used the color coded temp gauge. You can use a number temp guage if you like. This is from the Kawi service manual.
Danzig
Post by Danzig »
thermostats open at 108 degrees also
liquitisplit80
Real Name: Roy
Thanks Harley.
The numbered gauge is what it came with. I assume from the diagram the temp ranges are all the same for different manufacturers?? So the red zone on the JD's start at 200 degrees correct?
'78 Spitfire
82 Trailfire 340
'80 Trailfire 440
'80 sportfire
'81 liquifire
Here is a picture of the two styles of gauges side by side.
http://www.newbreedparts.com/newbreed/i ... 28x228.jpg
Larger version of that photo: Image
The red zone starts at 230 which is about the boiling point of antifreeze. Normal operating temp about 150.
liquitisplit80
Real Name: Roy
Thanks everybody for the inputs!
I was running on very marginal trails this past week due to the 40+ temps we had and my temp gauge got up to 160 degrees. First time it ever got that warm so I was a little concerned when I lost power going up a steep hill. I shut it off and let it cool down, changed plugs and belt. It fired up first pull and ran great all the way home. Shut it off again then went back out about an hour later and it did not want to idle. Not sure whats going on.
:needsnow:
'78 Spitfire
82 Trailfire 340
'80 Trailfire 440
'80 sportfire
'81 liquifire
Check your ignition coil.
