The next step was getting the drive clutch re-calibrated. I first tried a 46.5 gram weights, but they did not allow the motor to reach full RPM. I purchased another set of lighter weights to try out. One thing to notice was the the old series "B" wieghts that fit into a Comet 108 do not fit into the Cat drive clutch.
The drive clutch was already removed from the motor in the tear down last spring. Taking it apart and installing new wieghts was pretty straight forward, but I am going to review the process here. The procedure is very similar for servicing a Comet 102-C or it's modern derivatives.
First step is to loosen all the cover bolts and then hold down on the cover and remove the final bolts. Note that it's spring loaded so use caution:
With the cover removed, the spring comes right out. Note that a stiffer spring raises the engagment RPM, while a softer or worn spring lowers it:
