Packers29
Posts: 219 Joined: Sun Jan 12, 2014 11:28 pm
Real Name: Andrew Engels
Post
by Packers29 » Sat Jan 18, 2014 9:12 pm
So today I worked on the trailfire today. I have a problem it starts with 1 pull on half choke good right. Well when I unchoke it the engine races can't figure out why?
So if someone could help that would be great.
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
Posts: 1386 Joined: Sat Dec 14, 2013 3:39 pm
Post
by sledhead16 » Sat Jan 18, 2014 10:51 pm
Your choke would be throwing more fuel at it (obviously) but how does your idle adjustment look?
Packers29
Post
by Packers29 » Sat Jan 18, 2014 11:33 pm
What the service manual said 1 1/2 turns. But what I cant figure out is it runs fine on half choke but when taking that off it revs really high.
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
Viktory2k1
Posts: 157 Joined: Thu Dec 13, 2012 6:56 pm
Post
by Viktory2k1 » Sat Jan 18, 2014 11:55 pm
huge air leak?
Current:
77 John Deere Cyclone 440
98 Yamaha SRX700
Past:
1968 Rupp GT300
1970 Evenrude Bobcat 440
1976 Arctic Cat Cheetah 440
1976 Ski-Doo TN'T Everest 440
1978 Yamaha Exciter 440
1979? Yamaha Enticer 300
1979? Yamaha Enticer 250
1987 Polaris Sprint 340
Post
by sledhead16 » Sun Jan 19, 2014 9:36 am
my next guess would of been an air leak like Viktory2k1 said, have you pulled the carb and cleaned her all up?
Posts: 2975 Joined: Thu Jul 14, 2005 12:00 am
Post
by harleysportster » Sun Jan 19, 2014 9:43 am
-Idle speed set to high
-Slide in the carb sticking
-Float level is high.
'78 Liquifire (CrossCountry Clone)
'80 Liquifire (sold)
Packers29
Post
by Packers29 » Sun Jan 19, 2014 9:50 am
Yupp I Cleaned the carb soaked it up, ajusted the idle speed to what it said set the float 22mm from the gasket rib so its parallel, set the air screw 1 1/2 turns out. maybe i need to check the crank seals?
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
jdrob
Posts: 1212 Joined: Thu Feb 25, 2010 1:23 pm
Real Name: Rob
Post
by jdrob » Sun Jan 19, 2014 6:14 pm
Check the rubber intake boot to see if it's cracked anywhere.
Jdrob
Packers29
Post
by Packers29 » Mon Jan 20, 2014 11:25 am
So I've decided to replace the crank seals. Since I don't know the history of the sled
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
