So today I worked on the trailfire today. I have a problem it starts with 1 pull on half choke good right. Well when I unchoke it the engine races can't figure out why?
So if someone could help that would be great.
Need some help
- Packers29
- Real Name: Andrew Engels
Need some help
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
Re: Need some help
Your choke would be throwing more fuel at it (obviously) but how does your idle adjustment look?
- Packers29
Re: Need some help
What the service manual said 1 1/2 turns. But what I cant figure out is it runs fine on half choke but when taking that off it revs really high.
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
Re: Need some help
huge air leak?
Current:
77 John Deere Cyclone 440
98 Yamaha SRX700
Past:
1968 Rupp GT300
1970 Evenrude Bobcat 440
1976 Arctic Cat Cheetah 440
1976 Ski-Doo TN'T Everest 440
1978 Yamaha Exciter 440
1979? Yamaha Enticer 300
1979? Yamaha Enticer 250
1987 Polaris Sprint 340
98 Yamaha SRX700
Past:
1968 Rupp GT300
Re: Need some help
my next guess would of been an air leak like Viktory2k1 said, have you pulled the carb and cleaned her all up?
Re: Need some help
-Idle speed set to high
-Slide in the carb sticking
-Float level is high.
- Packers29
Re: Need some help
Yupp I Cleaned the carb soaked it up, ajusted the idle speed to what it said set the float 22mm from the gasket rib so its parallel, set the air screw 1 1/2 turns out. maybe i need to check the crank seals?
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
- jdrob
- Real Name: Rob
Re: Need some help
Check the rubber intake boot to see if it's cracked anywhere.
Jdrob
- Packers29
Re: Need some help
So I've decided to replace the crank seals. Since I don't know the history of the sled
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
