Kawasaki clutch removal
Loveofold
Post by Loveofold »
Greetings from old, wishing to learn
Have a 1980 JD Liquifire with a Kawasaki clutch 1977-78 Patent No's 4051739 and 4052908. Have taken a comet 102-C off of my 1981 parts sled with home made clutch puller. Need info on Kawasaki clutch that is on my 1980 Liquifire, to make a puller and remove. Model no. would help so I can view one on line, and Bolt length and thread size would definitely be a bonus. Is threads on bolt metric, fine thread, etc? have seen 2 on line, one with threads by the bolt head and the other with threads past halfway in towards the crank entry shaft, which one do I need to make?
Next question--- Have read forum on transmission oil replacement on front of engine, and am missing yet where to add oil at. Window, even with flash light is hard too tell oil level. The little hole is clear and clean, that one is suppose to check, Just would like better clarification on add hole location. Have checked chaincase, and oil injection bottle is 2/3rds full. Tank cleaned, old fuel pump rebuilt, with 2 gaskets needing holes for proper working, carbs cleaned. Engine runs, and would like original clutch on it. have 2 correct belts new 68715, and 2 new belts JD for later model Liquifires 69170
Please help before snow disappears, would like to see how much better the 1980 440 is compared to my 1976 liquifire.
Respectfully
loveofold
Should one have method to ones madness, that one is not necessarily MADD
JTQ
69camaro
Real Name: Duane Gjerseth
Re: Kawasaki clutch removal
Post by 69camaro »
I bought a new Kawasaki clutch puller for Invaders and Intruders. I can do some measurements but for as cheap as they are wouldn't just be easier to buy one. I think mine was like $24 shipped.
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
69camaro would you be able to send a pic and details of your clutch puller as I will need one and want to get the right one for my liquifire
Loveofold
Post by Loveofold »
69 Camaro
First, 69 was a very good year even for Pontiac, I remember all too well. Please send a pic, or tell me model number for clutch puller RE: per my question above. I am cheap, old, and tight.
Thank You for your quick reply, I really appreciate it. Measurements would be awesome.
Respectfully
Loveofold
JTQ
Loveofold
Post by Loveofold »
PS to 69 Camaro
Should the puller resemble the Comet 102C puller with threads next to hex head, correct bolt and thread size might work, bolt cost 3.29 about and sold close by. could than use the 3/8 ths no 8 hardened shaft that I used on pulling the 102C comet. In the mean time I will inspect the Comet I took off of the 2,000 mile 81 parts sled.
Thanks Again
Respectfully
Loveofold
JTQ
Not to tell you what to do, but the crank and bearings are much more expensive to replace than the $24 puller should you make a mistake. I saw a guy ruin his engine because he borrowed my JD puller to remove a clutch on an Arctic Cat machine. It made me sick to watch the proceedings, but I could not talk him out of it.
Heard an idea on wrapping Teflon tape around the bolt filling the clutch hole with water and the sled set on its side and then screwing the bolt in and let it freeze over night and its supposed to be successful???? Yay or nay on this?
Loveofold
Post by Loveofold »
The number 8 hard bolt drilled out 3/8' and 4.5" long with 3/8' no 8 hardnessshaft, grease both ends worked great for me, on my comet 102C clutch on 81. POP it came easy.
Still looking for thread specs on Kawi clutch removal tool for replacing the Kawi clutch with comet 102c (see above)
Appreciate the warnings too..
Have been restoring cars, mahogany boats, since 1972 Frozen motors and all
If all else fails, smart people do not repeat their mistakes.
JTQ
Thanks too all
Loveofold
JTQ
http://www.ebay.com/itm/Clutch-Puller-C ... 0799041842
Does this look like it would work well?
Loveofold
Post by Loveofold »
Greetings
Found one on the internet here in Wisconsin, have a little over $11.00 invested total with shipping. Kawi clutch came off easy, 102-C went on easy, cheap easy job and thank you everybody.
Respectfully
Loveofold
JTQ
