wont rev over 7500.....80 Liquifire
- liquifire1
Ok....I can't find a forum that describes all my circumstances
1980 Liquifire
when its colder (like first 10 - 15 minutes) of running it runs fine in the top end it pulls @ 8200 no prob
when the sled warms up (like 10 miles into ride) it wont rev when I give WOT it will got to a little over 7000 and "that's it" I even got one little backfire at WOT (out the pipe)
I unplugged the engine to isolate problems and it persists.....
It runs fine in the low end and I can feather it along up to about 2/3 throttle with the engine running under that 7000 mark without a burble but if I try to push beyond that it just wont go above........makes more noise but wont push past
it has the factory coil and wires (is this the problem??)
ran fine last year and "I think" the carbs are pretty clean (I gave them a good hose down with carb cleaner, like bowls off)
a plug swap will sometimes temporarily help, but sometimes not...
any help from the pros here would be appreciated
Jon
1980 Liquifire
Jon
80 Liquifire 440 x 3 (1 runs...sometimes properly)
Re: wont rev over 7500.....80 Liquifire
What do your plugs look like after it has warmed up and starts to bog down?
- liquifire1
toasty brown...both of them
like a toasted marshmallow
Could be starving for fuel.
Could be just a tad bit lean.
Could be a clutch issue.
Could be the engine temp is too high.
- liquifire1
Here is pic of the plugs
- liquifire1
The clutch issue...yup maybe...
But if I got a backfire when I was holding it to the bar doesn't that mean too much fuel?
temp gauge was at the bottom (and it works) so I don't think it was too hot?
A faulty ignition coil can act up like you're describing. Fine at cold start up but fails after it's heated from running.
That Girl Racing
- Real Name: Peter
The backfire is from being lean or a late spark. I will also go with a bad coil. Could also be a crankseal
Picture looks like a lean condition to me.
- liquifire1
Ok...
I put a new coil on it and just got back from a 15 mile run and it ran well the whole time, so hopefully that solves it.
I really appreciate all of your input and help!
Jon
Jon
- liquifire1
Yeah it is a little...hmmm?JDT wrote:Picture looks like a lean condition to me.
