Fuel economy at midrange from my understanding. In the Invader world the carbs are known as "econojet carbs".motoXman wrote:Can anyone tell me what Im losing by going to the non power jet carb?
Carb swap?
Re: Carb swap?
Re: Carb swap?
I have a set of used VM38s for sale.
Re: Carb swap?
Thanks, i will keep them in mind. likely will be staying 36mm though, I may be going flat slide for better throttle response.
1980 Liquifre 440 survivor
Re: Carb swap?
I did some measurments today for the flat slide carb. Looks like it may be a tight fit, I didnt realize the mag side carb pretty much rests on the steering colum!! &%#) The overall height is a bigger dimension, so if its anymore than 3mm longer on the bottom I will have a problem. Looks Like I may be staying with the VM36 round slide carbs afterall
- Real Name: Lloyd
Re: Carb swap?
Too bad you couldn't borrow a flat slide and see if it fits.
I know I am curious to know how those carbs would work
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
Re: Carb swap?
Well my friend that races and wrenches for a pro team says it will be added throttle response because it's a shorter carb, less distance for the fuel to travel on demand. If the flat slide carb is only taller not longer it will work. There's not very good info online for these. Being its a big name like Mikuni you would think they would have better literature.
- Danzig
- Real Name: Paul File
Re: Carb swap?
Get an Aaen Carb tuning book of you are serious about this carb swap to flatslides.
Re: Carb swap?
I can tell you from my own personal experiance that my 80 l/f has 40s on it and works great, this is not a stock engine though, its an ice oval sled, if you want to learn a bit more about carbs and jetting then find a copy of the arctic cat 75 z competition manuel, the z is also a t7, and when you put a degree wheel on a 75 z 440 and a 80 l/f they are extremly close to each other (hint hint for anyone looking to mod a liquifire)
Re: Carb swap?
Also as danzig said the aaen book is a must have! !!! You really should have a good basic knowledge of carbs and testing procedures before you dive into his books or else you will be more confused than before lol!
