Mark
2016 ride with the champs
buckeyetrailfire
- Real Name: Mark Elliott
There are only 80 days until the 2016 ride with the champs . who's going? who's ready and who's not?
Mark
Mark
1979 Trailfire 440
1980 Trailfire 340
1980 sportfire
1980 Trailfire 340
1980 sportfire
Re: 2016 ride with the champs
Friday's Looselugnutz "Cameron Amber Memorial Poker Run" is being modified in an effort to attract more participants. There will the the "normal" poker run ride and one where you'll spend more time on the trail and less time at the watering holes. And of course there's always the "Friday Night Fishfry" that I will host again this year. We (jdsleds) will be making a very important announcement that evening as well... hope you all can make it. I'll be working on a head count when time gets closer.
Jd sled rider
- Real Name: Lincoln Huffman
I plan on attending and should be putting the finishing touches on two sleds next week. Here is a pic of one. Later lincoln
- image.jpg (19.4 KiB) Viewed 12311 times
- KamJD600
- Real Name: kameron peck
whare is ride with the champs located
Kam, the Ride With The Champs is an annual event sponsored by the Snowmobile Hall of Fame in St. Germain, WI. For more information visit the SHOF website at www.snowmobilehalloffame.com
I made post last year explaining everything that goes on around it: http://www.jdsleds.com/community/viewto ... 26&t=17850
Booked our room at the Whitetail when we checked out last Feb. So, I guess we have to go!
Looking forward to it!
- 340sracer
- Real Name: glen wasmuth
We are planning to participate in the ride with the champs for the first time. Will be bringing the 340 s that I raced in the Winnipeg St. Paul race in 1975. I do have some questions , The first one is this is the first time I have run a cleated track in almost 40 years and I was wondering if most people run studed tracks and carbide wear bars on the skis?
Another question is regarding helmets, I did have my John Deere helmet that I used in the race restored this last winter but I understand it is not safe to ride with it so I am in the market for a new helmet.. I'm considering buying a full face helmet with the electric shield and I was wondering if there is any suggestions . I was looking at helmets on the Internet and it says there's one model that you can wear goggles with the electric shield and I was wondering what the purpose of that would be ?
Thanks, Glen
Thanks, Glen
- 340sracer
Another question I have is we are planning on coming with the motorhome, is there any place to park and plug-in?
Glen, I would check with the St. Germain, WI Chamber of Commerce about parking the motor home. Here's their website: http://secretsofthenorthwoods.com/
- acesillini06
- Real Name: Matt Cappel
That will be awesome to see your 340s on the ride! I didn't run studs or carbides on the ride and did just fine. They don't go that fast. As for helmets if you restored your old helmet it will work just fine as for new helmets an electric shield only works if you have the proper wiring to power it.
- 340sracer
Will the 340s have enough capacity to spare to power up an electric shield and if it does where would a person tap into the system . Maybe the new helmets have good enough ventilation that you do not need an electric shield ????
- acesillini06
Most helmets offer anti-fog, anti-scratch, UV filtering, dual layer face shield. So I think no real need for the electric shield.
- 340sracer
Thanks everyone for the info
Glen, good to hear of your plans.
A fresh set of carbides on the skis makes the corners a little less white knuckle. Picking the track is up to you. I have run the Vintage Challenge 7 times on the X8, without any picks. We always run into a few corners that are icy and make you hold your breath.
I run an original Deere full face helmet. Yes you are supposed to throw them away every 5 years or so. I run the original Vari-shield, but run it open much of the time. My observation is the the goggles are a pain, the guys are always wiping the fog out or something.
Several of us found the 340/S to dart so bad on a hard pack trail that it was scary, That is why several have switched to the plastic ski set-up.
