Liquifire mufflers
Liquifire mufflers
Did the mufflers change at all from 1980 to 1984 on the Liquifire line?? I purchased one that's marked "83 Liquifire" but it does not resemble my 1980 muffler. Can anyone shed some light on this??
1988 & 1991 Polaris Indy 650s
- Real Name: Lloyd
Re: Liquifire mufflers
All the 80-84 Liquifire mufflers are the same part number
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
- Real Name: Charlie Vierke
Could it be possible one has muffler off a Invader. I don't remember what the Invaders looked like though either but wondered if they were different and would help for more power.
- Packers29
- Real Name: Andrew Engels
Picture would be helpful to tell which is which
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
- Real Name: Lloyd
Invader mufflers don't fit in a Liquifire pan
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
- Real Name: Lloyd
Even the Trail and Sportfie mufflers look the same, Except for the L welded in them
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
The welded "L" is the only visible way to distinguish between the two types, and they are not interchangeable.ljm wrote:Even the Trail and Sportfie mufflers look the same, Except for the L welded in them
That's what I thought. My old one has the "L" and the one shipped to me does not. Welp, back to the drawing Board I guess.
Liquifire muffler has the "L" the others don't and they won't interchange.
The invader muffler is similar but has a large bulge on the bottom side, I have a couple LF mufflers if you want to PM me. Jim
Back in the day it was said that the "L" welded on the Liquifire pipe was just that!! Liquifire, and others said "L" was for LOW RESTRICTION...Rob.
