looking to replace carbs on 81 liquifire
bajorege
Real Name: Gered
Post by bajorege »
Has anyone swapped powerjet carbs over to non powerjet carbs on a 81 liquifire. If so what size and what jetting. Or if I could find a good pair of used power jet carbs that would be cool too. Mine are very pitted inside and out.
Re: looking to replace carbs on 81 liquifire
Finding some pj carbs would be best as they are used as performance carbs, more crisp jetting setup per throttle stage than say a standard 38mm carb setup where you have more of a vague fuel hump to get over between positions.
I believe there are a few machines out there with 38mm carbs in lieu of the stock power jet setup. Seems like there was a thread dealing with this situation a few years back, but I can't guarantee that. Perhaps someone who has dealt with this will provide some details. I think clutching mods are part of the equation.
bajorege
Real Name: Gered
Post by bajorege »
Thanks for the responses guys I too am thinking I just need to find stock used pj carbs. It would probably be a lot to figure out a non pj carb setup
I'm doing this right now on my Invader, swapping to VM38s. I got recommendations from the Kawasaki guys to go to 300-320ish mains and 30-35 pilots. Carbs are jetted 300 & 35 and installed but not tested yet.
smitfire
Real Name: Dustin Smit
Post by smitfire »
I have a fresh set of original liquifire pj carbs. Came off a running sled this fall. I parted out the whole sled.
bajorege
Real Name: Gered
Post by bajorege »
Keep me updated on the vm38s I'm interested to see how that works
smitfire wrote:I have a fresh set of original liquifire pj carbs. Came off a running sled this fall. I parted out the whole sled.
If you have the stock air box, I'd go with the PJ carbs. You will enjoy the ride....
The 38s will work, but I really believe the pj tuned carbs help the sled pull smoother, crisper and more efficiently and there isn't any lag like there could be with 38s
