WANTED: fuel tank
tedium27
Real Name: Terry
WANTED: fuel tank
Post by tedium27 »
Need a fuel tank for a newly acquired JDX6C. Fuel Gauge nipple rusted out, or a fix for it? Obviously, I have the steel tank. :wall:
Steven Rempel
Re: WANTED: fuel tank
Post by Steven Rempel »
if you cant find a steel tank a little closer to you, I have many tanks in good condition, none I have are perfect. But will work with out issue. I have cleaned the inside of the tanks with acid and then washed out, and before placing on the shelf put 1 ounce of oil in side to help stop any rusting during storage.
I live in pretty far from you so if you find one closer no problem
tedium27
Real Name: Terry
Post by tedium27 »
Thank you for the quick response Steven! Mine is the angular very forward tank. How much would it cost me to talk you out of one?
Steven Rempel
I have one I had a look at the inside is in good shape. It has a small dent in the front passenger side. but it did not leak when I cleaned out the inside. It has no fittings or fuel caps. I will post some pics if you are interested. I think 30.00 plus shipping. I might have a fuel inlet fitting but not sure of it condtion. let me know.
I have other ones with no dents that I have not clean out yet. one looks to be a good contender, no sign of leaks or rust that I would be concerned about. 20.00 for that one sold as is. also does not have any fittings or fuel caps
smitfire
Real Name: Dustin Smit
Post by smitfire »
I have a plastic tank from an 800 model
tedium27
Real Name: Terry
Post by tedium27 »
I'm not sure on fitment, but I'll check it out. How much?
The plastic tank will fit if you trim a little plastic from the bottom of the grill and get the longer tank straps. It's 6 gallons instead of 5. It's a good upgrade, I did it on my 295/s.
I believe I have an extra steel tank if no one else has one.
smitfire
Post by smitfire »
I sent you a PM. The longer tank straps would be included as well.
