Fire series suspension grease fittings
Does everybody install grease fittings when doing suspension remove for maintance ?
Re: Fire series suspension grease fittings
Everytime
Yep, just drill a hole and weld a 1/4-24 nut on to accept a grease zerk.
No, I use Nevr Seize. I would like to see a show of hands of those who religiously grease the shafts.
Sleds...
2xJOHN DEERE SPRINTFIRE 1983.
YAMAHA GP292b 1973
OCKELBO Trioman 1975
YAMAHA SRV 1982 (shrinked)
YAMAHA SRV 1990
YAMAHA SRV 1991
LYNX Rave 600ACE 2013
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
I recently pulled a suspension on a liquifire to replace a hydraulic shock. I had gone through this suspension about 5 years ago and had anti-seized all the shafts at that time. I checked them and they all still moved freely and were easily pushed out. Hope that helps.
81 sportfire
83' liquifire x2
81'liquifire
80 sportfire
81& 83 Trailfire 440
83' liquifire x2
81'liquifire
80 sportfire
Why does this image of the TinMan in Wizard of Oz keep popping up into my head?
- Real Name: Mark Elliott
I do also it’s good to check those bearing every 2 -3 years while the skid is out . You don’t want to lose a bearing out on the trailWinnipegStPaul9 wrote:No, I use Nevr Seize. I would like to see a show of hands of those who religiously grease the shafts.
1979 Trailfire 440
1980 Trailfire 340
1980 sportfire
1980 Trailfire 340
1980 sportfire
- Real Name: Lloyd
I use never seize.
I have had some with grease fittings. Hardly ever greased them.
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
