Fire series suspension grease fittings
raiderfan
Real Name: Mark
Post by raiderfan »
Does everybody install grease fittings when doing suspension remove for maintance ?
smitfire
Real Name: Dustin Smit
Re: Fire series suspension grease fittings
Post by smitfire »
Everytime
427cobra
Real Name: Eric
Post by 427cobra »
Yep, just drill a hole and weld a 1/4-24 nut on to accept a grease zerk.
Eric A.
No, I use Nevr Seize. I would like to see a show of hands of those who religiously grease the shafts.
SS440-80
Real Name: Robert
Post by SS440-80 »
:dance:
Sleds...
2xJOHN DEERE SPRINTFIRE 1983.
YAMAHA GP292b 1973
OCKELBO Trioman 1975
YAMAHA SRV 1982 (shrinked)
YAMAHA SRV 1990
YAMAHA SRV 1991
LYNX Rave 600ACE 2013
pkehrer
Real Name: Paul Kehrer
Post by pkehrer »
I recently pulled a suspension on a liquifire to replace a hydraulic shock. I had gone through this suspension about 5 years ago and had anti-seized all the shafts at that time. I checked them and they all still moved freely and were easily pushed out. Hope that helps.
81 sportfire
83' liquifire x2
81'liquifire
80 sportfire
81& 83 Trailfire 440
Why does this image of the TinMan in Wizard of Oz keep popping up into my head?
buckeyetrailfire
Real Name: Mark Elliott
Post by buckeyetrailfire »
WinnipegStPaul9 wrote:No, I use Nevr Seize. I would like to see a show of hands of those who religiously grease the shafts.
I do also it’s good to check those bearing every 2 -3 years while the skid is out . You don’t want to lose a bearing out on the trail
1979 Trailfire 440
1980 Trailfire 340
1980 sportfire
ljm
Real Name: Lloyd
Post by ljm »
I use never seize.
I have had some with grease fittings. Hardly ever greased them.
Several Deere's
Several Kawasaki's
ACSCC #1534
