I am trying to add a tachometer to my 76 cyclone 340. I picked up a NOS AM52346.
It has a yellow lead for light, and two leads for the tach. According to my wiring diagram, the yellow/red wire should connect to black, and the red should connect to brown on the sled. When I connect it this way the tach reads high. Maybe double what it should or more. I connected to the brown circuit at the wiring block.
Any ideas?
76 Cyclone Tach wiring
farleyjd400
- Real Name: Andy
Re: 76 Cyclone Tach wiring
That part number comes up for the mid mount snowmobiles with points ignition. Does the tach have a fuse in line of the yellow/red wire? If it does not then it will not work for you ignition
1976 Cyclone 340
1977 Cyclone 440
1978 Cyclone 440
1977 Cyclone 440
1978 Cyclone 440
- sledstorm
- Real Name: Tom Mannion
No fuse in the line. The instruction sheet has 73, 74 listed, and then Spitfire and Trailfire.
- sledstorm
So I believe the 76-78 Deeres used the AM 53193 tach. All others are not compatible. Maybe its a 2 pulse vs 6 pulse thing? Anyone know?
Are there any other tachs I can use on my 76 Cyclone?
