1984 Trailfire cylinders
hounds84lhs
Post by hounds84lhs »
Hi, I am in the process of going through my 84 engine and it looks like on of the cylinders is bad. i have a 1980 440 parts motor but noticed the cylinders are slightly different? After some research I see there are different part numbers for the later years TF cylinders. Would/can I use one from each engine? Thanks in advance for any help.
83 Trailfire
83 Sprintfire
81 Liquifire
80 Trailfire 340
80 Trailfire 340
78 Spitfire
76 Liquidator
smitfire
Real Name: Dustin Smit
Re: 1984 Trailfire cylinders
Post by smitfire »
No, stick with the later ones. They are an update with the ignition
guitardude081
Real Name: Jack Durand
Post by guitardude081 »
I would personally send them out to Millenium or US Chrome and have them replated with nicasil. Wiseco will sell your pistons with nicasil rings. I think all said and done, I’m into my ‘83 motor $700 with gaskets. I haven’t fired it yet but I’m pretty excited to start showing it again this summer and riding next winter. It will be much more durable than the original chrome lined motor.
~Jack
Owner, Durand Motorsports
1983 Trailfire LX
(3)1974 295/S
1975 340/S
(2) 1978 Liquifire
2003 Ski Doo Renegade 600HO
hounds84lhs
Thanks for the info.
I was going thru my parts engines and found something interesting. These are all off of TA440 motors. One has TA440A-D202 and the other has TA440A-C202? Is there any difference?
83 Trailfire
83 Sprintfire
81 Liquifire
80 Trailfire 340
80 Trailfire 340
78 Spitfire
76 Liquidator
hounds84lhs
Sorry I did not add the last part of my question. The 84 engine is marked TA440-F202. Does the C, D and F mark the year manufactured or?
83 Trailfire
83 Sprintfire
81 Liquifire
80 Trailfire 340
80 Trailfire 340
78 Spitfire
76 Liquidator
guitardude081
The F202 uses copper rings instead of paper/steel gaskets. The F202 also has a little extra go fast.
~Jack
1983 Trailfire LX
(3)1974 295/S
1975 340/S
(2) 1978 Liquifire
