Cyclone mikuni carb
JDMIKE8100
Cyclone mikuni carb
Post by JDMIKE8100 »
Had this carb off twice,cleaned well with carb cleaner and has a new carb kit.
Still not getting fuel to motor,plugs dry.
Fuel pumps @ carb into cup.
Machine has not run for a long while,have lots of spark and compression.Thanks.
Re: Cyclone mikuni carb
If I'm reading this correctly you have fuel at the carb but not in the mixing bowl?
JDMIKE8100
The bowl is filling but fuel is not delivered to motor.
Will it run with manually introduced fuel?
JDMIKE8100
Yes
Swap out the carb if you can. Something has to be wrong with that one.
JDMIKE8100
That's what I am thinking. Do they pit or oxidize over time?
They can, especially if ethanol has been through them or if critters have peed inside. Something is blocking somewhere.
JDMIKE8100
There was a mouse nest in the airbox, never made the connection till now.Thanks.
:sick2:
