Cyclone mikuni carb
- JDMIKE8100
Cyclone mikuni carb
Had this carb off twice,cleaned well with carb cleaner and has a new carb kit.
Still not getting fuel to motor,plugs dry.
Fuel pumps @ carb into cup.
Machine has not run for a long while,have lots of spark and compression.Thanks.
Re: Cyclone mikuni carb
If I'm reading this correctly you have fuel at the carb but not in the mixing bowl?
- JDMIKE8100
The bowl is filling but fuel is not delivered to motor.
Will it run with manually introduced fuel?
- JDMIKE8100
Swap out the carb if you can. Something has to be wrong with that one.
- JDMIKE8100
That's what I am thinking. Do they pit or oxidize over time?
They can, especially if ethanol has been through them or if critters have peed inside. Something is blocking somewhere.
- JDMIKE8100
There was a mouse nest in the airbox, never made the connection till now.Thanks.
