I have a 73 JDX4 with a K2952AX. I am just starting the process to make this a rider machine.
Some questions I have so far are: can I find some new rubber motor mounts? Can I find a fuel check valve that goes in the fuel tank? Matt has sent me the link for the engine seals.
I did a compression check and both cylinders are 120+. I am ok with that.
I have some photos of the machine.
Obviously I need a seat, and not sure how the fuel tank is going to clean out. Hopefully this will be a worthwhile project.
73 JDX4 project
rkchainsaw
- Real Name: Randy
Re: 73 JDX4 project
Not bad at all. Looks pretty straight up and you even have the engine cover.
rkchainsaw
- Real Name: Randy
Re: 73 JDX4 project
I tore it down a little tonight and some of the things I will need to find are some rubber motor mounts and clutch removal tool. I'm also in the process of cleaning the rust out of the fuel tank. Is there a good aftermarket vintage snowmobile parts magazine/website????
rkchainsaw
- Real Name: Randy
Re: 73 JDX4 project
Working on it today. Trying to pull the clutch off. I want to put new seals on the crankshaft without tearing it down. Anyone know where I can find a jdm-28 clutch puller or another one from a different machine that will work?
Re: 73 JDX4 project
I think Newbreed Parts has them.?
rkchainsaw
- Real Name: Randy
Re: 73 JDX4 project
I was reading the service manual about the gas and oil recomendatios. The manual says that if you don't use JD 2 cycle oil(50:1) you should be mixing off brand oil at 20:1. Wow that is a rich mixture. The fuel I harm using to try and get it running is 32:1. Any comments?
[img]
jdsledhead
Re: 73 JDX4 project
Just reading this thread that hasn't been updated in exactly one year. What a coincidence. haha.
I would run 50:1 with any modern 2-stroke "mineral" oil. AKA - standard oil, doesn't need to be synthetic. I run Arctic Cat "injection oil" as that's what my newer Cat runs (no power valves).
Back to the sled - that chassis looks CLEAN. Jealous! My first sled was a 73 JDX4. Unfortunately, it succumbed to rust about 10-15 years ago. I was loosely looking for another one, finally finding one about a month ago that's clean enough to restore. Yours looks even better!
Glad to read you got the crank seals done. The Walbro carbs can be a bit of a pain to tune, but IMO worth the effort to learn. Clean the fuel system well, run a filter, rebuild the carb.
Good luck getting it back on the snow!
Tim Kudla
73 JDX4
80 Spitfire
82 Trailfire 340
84 Trailfire 440
10 SnoPro 500
73 JDX4
80 Spitfire
82 Trailfire 340
84 Trailfire 440
10 SnoPro 500
Re: 73 JDX4 project
So I have a JDX4 Special sled that I have had for over 40 years. The engine is from my old 72 JD 400 so kind of a Frankenstein! But it runs sweet. I ride it every year. This year I am doing some refurb on it and I saw in this thread that motor mounts were needed. I need them also is there a source or replacement pieces?
Re: 73 JDX4 project
A Bobcat part is said to be a useable substitute. Google: Bobcat 6560633
