83 Trailfire 440 lx oil pump adjustment
RICKZ
Real Name: Rick Zeinert
Post by RICKZ »
Just purchased 2 440 Trailfire lx models . While cleaning them I noticed one of the oil pump cables that the jam nuts are loose and out of adjustment. What is the proper setting for these so I get the cable set correctly ? Thanks
Re: 83 Trailfire 440 lx oil pump adjustment
Hi Rick - here is a link to download the Manual, it has the instructions for adjusting the oil pump: http://vintagesnow.com/John_Deere_files ... ire_OM.pdf
I'm pretty sure that any time I've done it, I just tension the oil pump wire so it starts moving with the throttle lever, and made sure the pump is wide open when the throttle is too.
RICKZ
Post by RICKZ »
Thanks Matt, I will give it a try.
