Is there a source or similar replacement part that can be had for the rubber seal on the metal fuel tank caps on the earlier mid mounts with steel tanks?
Mine is broken and I checked my parts pile and the rubber is torn on all of them.
Mid mount/JDX Fuel Tank Cap Rubber
1973 JDX8 (maybe parts sled)
1974 JD400
1975 JD800
1982 Trailfire LX 440
1974 JD400
1975 JD800
Re: Mid mount/JDX Fuel Tank Cap Rubber
Just took a look at the link - isn’t that for the fuel inlet fitting for a poly tank?
1974 JD400
1975 JD800
1974 JD400
1975 JD800
Looks like it. Prolly going to have to fab up your own.
I wonder if I could find a similar sized oring and make it work
1974 JD400
1975 JD800
1974 JD400
1975 JD800
