Mid mount/JDX Fuel Tank Cap Rubber
Cdnturboz
Real Name: Steve
Post by Cdnturboz »
Is there a source or similar replacement part that can be had for the rubber seal on the metal fuel tank caps on the earlier mid mounts with steel tanks?
Mine is broken and I checked my parts pile and the rubber is torn on all of them.
1974 JD400
1975 JD800
1982 Trailfire LX 440
Re: Mid mount/JDX Fuel Tank Cap Rubber
Cdnturboz
Real Name: Steve
Post by Cdnturboz »
Just took a look at the link - isn’t that for the fuel inlet fitting for a poly tank?
1974 JD400
1975 JD800
Cdnturboz wrote: Mon Mar 20, 2023 9:28 am Just took a look at the link - isn’t that for the fuel inlet fitting for a poly tank?
Looks like it. Prolly going to have to fab up your own.
Cdnturboz
Real Name: Steve
Post by Cdnturboz »
I wonder if I could find a similar sized oring and make it work
1974 JD400
1975 JD800
