1974 JD 400 Project
Cdnturboz
Real Name: Steve
Re: 1974 JD 400 Project
Post by Cdnturboz »
Thanks for the reply! I ended up getting a Kimpex windshield that seems to fit good:
I’ll have to visit a local dealer and grab some screws then. All that’s left is repairing the seat and a few misc stuff - got it running pretty good and have taken the daughter out a few times already!
Steve M
1974 JD400
1975 JD800
1982 Trailfire LX 440
Ajc
Real Name: Andrew Clark
Post by Ajc »
The Kimpex windshields are better then the Sno-Stuff ones. I think Kimpex stopped making them so there getting hard to find.
1973 400
1975 800
1975 800 - (Parts)
1975 JDX8
I agree on the Kimpex deal. Sure is a clean sled!
Curlymurt
Real Name: Adam
Post by Curlymurt »
Cdnturboz wrote:I'm missing a bunch of those side cowling/panel screws - anyone know of a source to find them? Looking for ones that would look stock in appearance
I find a lot of nicer trim screws from the autopart stores. I tend to have better luck with AutoZone in my area. Granted, I don't really know what the OEM should look like
Sent from my SM-J100VPP using Tapatalk
1972 Deere 400
Cdnturboz
Real Name: Steve
Post by Cdnturboz »
Quick update on this thing - trying to get it ready for the vintage show/parade at CPTC out here in March.
Added new footwell grips/tape - found some stair tread tape that was wide enough and kept the yellow stripe for the JD theme.
Putting some new skegs on as well - a few last misc things and it should be ready to go.
1974 JD400
1975 JD800
Cdnturboz
Real Name: Steve
Post by Cdnturboz »
Still having issues with the Walbro WDA, found a couple bendix carbs, might try rebuilding on of these new ones and giving it a try again. Not sure if I want to go with the mikuni swap
1974 JD400
1975 JD800
What Walbro are you working with, and what are your specific problems?
Cdnturboz
Real Name: Steve
Post by Cdnturboz »
The WDA-32 which was off of a 73 400. It was fully rebuilt with an aftermarket rebuild kit. Used your advice on the salvaging Walbro carbs thread but still can’t get that bog gone.
It bogs real bad when at about mid range, almost when you go on and off the throttle.
As well the throttle is really hard to squeeze, like after 10 minutes of pulling the kids around it started to get hard to squeeze and almost sticks, been like this for a while now. I’m guessing something is binding.
I’ve tried a new throttle cable and no difference, I’m thinking it’s something at the throttle block- I had swapped the entire handle from a 75 300 when I first redid the sled (as it was nicer) thinking something must have been wrong with it.
1974 JD400
1975 JD800
Cdnturboz
Real Name: Steve
Post by Cdnturboz »
Reason I went to the Walbro from the original bendix was I could never get it to idle right even after a full rebuild of the engine and using a nos carb rebuild kit.
Thinking something was wrong with the original bendix so I think I’ll try one of these other ones I just got
1974 JD400
1975 JD800
It would help if you could determine if the bog is because of lack of fuel, or too much.
Cdnturboz
Real Name: Steve
Post by Cdnturboz »
Yeah that’s my plan to mess more with it this weekend - I’m going to try and fix the binding throttle first
1974 JD400
1975 JD800
Yes, absolutely get the throttle working correctly.
It may be possible to play with the choke to diagnose what is going on.
Cdnturboz
Real Name: Steve
Post by Cdnturboz »
:arrow: Took cable all off and lubed it with chain lube (that’s all I had) - seems 100% better than before. It was a new aftermarket cable, most likely my fault in forgetting to lube it the first time. Is there a better cable lube to use?
For the bog it seems to be in the mid range just before full throttle, full throttle is fine though. It seems to idle good, what’s a good idle RPM to set these at?
1974 JD400
1975 JD800
There is some personal preference involved. Obviously it has to be below clutch engagement!
I am thinking around 2000 rpm.
Steve,
Just a curious question: where did you source the footboard grip tape? That's pretty cool and very functional. You must have put the yellow stripe in yourself? Yellow piping for the bumper and tunnel perhaps?
