1980 Trailfire Part Out
Hello all, I have a 08/79 (1980) date code parts sled (incomplete) that my son and I have started to tear into.
I will start to post pictures of items as we get them tore off and cleaned up. If any immediate needs, let me know and I will be happy to help you out with pricing, I dont have a need for any TF440 parts at the moment. I will say, the hood and tunnel are in phenomenal shape, no major cracks, dents or issues - just small wear and tear/scratches. Also, 440 e-start engine...Located in Medina, OH USA.
Brad
Brad
Re: 1980 Trailfire Part Out
Airbox is complete, in good condition. Pieces have been cleaned and prepped.
Hood is in great shape. No cracks or issues with the fiberglass. Small scratches and basic wear. Hood vents, grill, headlight housing (light not avaialble), other pieces are in good condition. Would be a great donor hood or replacement for a project.
Backrest - Good conition. Chrome is rusty from the fasteners, but not pitted. Can be/needs to be polished for simple restoration. Small cracks in back rest plastic/padding, but a great surivor piece for your sled.
Engine - TA440A-D202 e-start engine case. Good compression, no carb, engine rotates freely, and cyinders look good. Engine covers, starter, air shroud cover, y-pipe avaialble. Battery box and e-start wiring harness avaialble too.
More engine photos...
Also, link to video of engine being turned over https://photos.app.goo.gl/GB2Ah53rppVmgXu39
Battery box, wiring harness and engine fan shroud sold. Thanks Keith!
Let me know if anyone is looking for parts. Happy to help work with you on items, as available.
Left and right side belly pans/side panels. Overall in fair->good shape. Two small cuts in the exhaust hump area otherwise, no major scratches or dents on clutch side. A good set as needed for spares or a wrecked sled.
- nothingbutadeere
- Real Name: Todd Landry
Hello,wondering if you have a complete driveshaft with the drivers in tack. Looking for the 8 tooth 2.52” drivers to replace the shaft and drivers for my ‘76 Cyclone.
Hello, unfortunately the driveshaft, and drivers already gone. Thanks for the interest. Good luck in your continued search!nothingbutadeere wrote: ↑Mon Nov 11, 2024 3:58 pm Hello,wondering if you have a complete driveshaft with the drivers in tack. Looking for the 8 tooth 2.52” drivers to replace the shaft and drivers for my ‘76 Cyclone.
Bigbuck308
- Real Name: CD
Do you have the console?
Negative. Unfortunately the console was cracked into a number of pieces, had to scrap.
Do you have a seat and if so would it fit an 82 liquifire?
