Had a good day
Popcorn popper
- Real Name: Steve
Had a good day
Had a good day. A 82 liquifire and two 80’s liquifires. Two have engines the 82 missing pieces of engine but i have spare.
Popcorn popper
- Real Name: Steve
Re: Had a good day
Also had the holy grail tr800
Re: Had a good day
Great find! I need to get my shop done so I can start restoring mine.
Dan
1981 Liquifire
1984 Trailfire LX
2018 Ski Doo Summit Sport
1981 Liquifire
1984 Trailfire LX
Re: Had a good day
Awesome stuff! Look forward to seeing your progress on these!
Re: Had a good day
That's great....seem to be a lot of 82s surfacing. Hope you also got the HSR with 82.
Popcorn popper
- Real Name: Steve
Re: Had a good day
What is hsr?
Re: Had a good day
The 82 and up sleds had a different ignition system know as HSR (High Speed Retard). The coil and CDI box is one unit, the flywheel and stator coils are different and the flywheel housing is different for mounting the CDI coil combo unit. Functionally, these boxes do what the name implies, they retard the ignition timing at high RPM. Basically makes the engine easier to start and then at high speed dials back the ignition timing to reduce the likelihood of burning it down.
Mark633CSi
Re: Had a good day
Were these the ones on Kijiji in Alberta!? Nice find!
Popcorn popper
- Real Name: Steve
Re: Had a good day
I have everything but the crankcase which he is still looking for. He believe the crankcase was boxed up in basement.Thanks for update i have flywheel stator and box.nick80lf wrote: ↑Wed Oct 09, 2024 12:29 pm The 82 and up sleds had a different ignition system know as HSR (High Speed Retard). The coil and CDI box is one unit, the flywheel and stator coils are different and the flywheel housing is different for mounting the CDI coil combo unit. Functionally, these boxes do what the name implies, they retard the ignition timing at high RPM. Basically makes the engine easier to start and then at high speed dials back the ignition timing to reduce the likelihood of burning it down.
Re: Had a good day
My opinion, having the casting that covers the flywheel would be pretty important since it is a unique piece. The two case halves I don't think are as important, I've added the holes for e-start to 80 cases. If you do a good job it would be very hard to tell a difference between an 80 case and an 82 case.
Popcorn popper
- Real Name: Steve
Re: Had a good day
Yes i also have the mag cover. Hopefully he can find cases. If not i have older one I could convert. Thanks
