Trailfire 340 cylinder on spitfire.....
swedefire
Post by swedefire »
Both kawi 340....
Other than cutting some cooling fins what would be required, if possible?
Is the bolt pattern the same, etc..?
Thanks!
/Magnus
Hey Magnus!
Glad to here from Sweden. The 340 Trailfire has the same interfaces as the Kawi powered Spitfires. So, aside from a slight triming of the cooling fins, everything else will bolt up, including the intake and exhaust manifolds.
Good luck!
-Joe Rainville
"Tech-Ed"
swedefire
Post by swedefire »
Thanks a bunch Joe!
Ill let you all know how it went...
Thanks!
/Magnus
Deleted User
Post by Deleted User »
I have to ask, if TF 340jugs will fit on a spitfire crankcase, then since TF 440 jugs will fit on a 340 case then would 440 jugs work on a spitfire case with some trimming as well?
swedefire
Post by swedefire »
Yes, probably by cutting the case but the problem will be to transfer the increased heat that a 440 will create....being only freeair....
The heads wont work either.....
/Magnus
