kawi ltd 4/6
kawi ltd 4/6
im looking for pistons for my 80 ltd 4/6. if anybody has any they would like to sell or know where i can get some it would be greatly apreciated, thanks.
kawi ltd 4/6
I wish I had some extra spares I could sell you, but I only have two and I just burnt down a piston on my 4/6. The pistons I bought did not come with rings. Do you know if Invader/Liquifire rings will fit the 4/6 piston?
Pete
Pete
Peter from Roblin, Manitoba
kawi ltd 4/6
You can just use regular invader pistons in that motor. The ring pin placement is different but it will clear all the ports.disfunctionals wrote: im looking for pistons for my 80 ltd 4/6. if anybody has any they would like to sell or know where i can get some it would be greatly apreciated, thanks.
kawi ltd 4/6
Thanks for the tip, Trucker, but my 4/6 engine uses considerably larger wrist pins than an Invader or Liquifire. I have the correct pistons for it and they do look like they'd take Liquifire rings, however I don't have a set to try. I think I'll order some and see how well they fit.Trucker wrote: You can just use regular invader pistons in that motor. The ring pin placement is different but it clear all the ports.
Pete
kawi ltd 4/6
You must have a 81 or 82 monohead 8 port motor if your wrist pin is bigger. The 4/6 motor uses the same pin as the invader and intruder. An if you have a monohead the rings are different but still available from dennis kirk along with pistons. The gasket kits you can get from manufacturers supply or Pats small engine.Liquifire 4/6 wrote: Thanks for the tip, Trucker, but my 4/6 engine uses considerably larger wrist pins than an Invader or Liquifire. I have the correct pistons for it and they do look like they'd take Liquifire rings, however I don't have a set to try. I think I'll order some and see how well they fit.
Pete
kawi ltd 4/6
Yes, mine is an 81 with a monohead. Nice to know the original rings are still available. Dennis Kirk doesn't currently distribute parts to Canada, but I understand that they have plans to do so in the very near future. Do you have a Dennis Kirk part # for the proper rings for my pistons? I have my LTD 4/6 sold to a buddy of mine who is nuts for Kawasakis but I am keeping the engine which I plan on putting into a Liquifire, hence my user ID. That 4/6 was stupidly fast until I popped a piston awhile back....the speedo was showing somewhere near a hundred when suddenly, there was dead silence. Fortunately, there doesn't seem to be any other damage to the mill.
Pete
Pete
kawi ltd 4/6
If its an 81 its not a 4/6 the 4/6 was only in 80 and had seperate heads and different cylinders.Liquifire 4/6 wrote: Yes, mine is an 81 with a monohead. Nice to know the original rings are still available. Dennis Kirk doesn't currently distribute parts to Canada, but I understand that they have plans to do so in the very near future. Do you have a Dennis Kirk part # for the proper rings for my pistons? I have my LTD 4/6 sold to a buddy of mine who is nuts for Kawasakis but I am keeping the engine which I plan on putting into a Liquifire, hence my user ID. That 4/6 was stupidly fast until I popped a piston awhile back....the speedo was showing somewhere near a hundred when suddenly, there was dead silence. Fortunately, there doesn't seem to be any other damage to the mill.
Pete
heres a link to the pistons
LINK
kawi ltd 4/6
trucker,
i talked to you on the phone the other day. im not real sure what i should do, your not the first one to tell me that invader pistons will work, and i agree with you. BUT my engine builder doesnt want to use them and wont make any promises if he does, so i figured id just see if i could find a set for it. what do you think?
kawi ltd 4/6
You could try calling Emerich sales 518-399-8574 they did have some in stock awile back but im not sure if they have anymore left.
