I got the carb slides on the throttle cable, and now they won't seat against the stops. They sit about 1" above the stop screw. What could be causing this?
~Jack
carb slides
- guitardude081
- Real Name: Jack Durand
carb slides
Owner, Durand Motorsports
1983 Trailfire LX
(3)1974 295/S
1975 340/S
1983 Trailfire LX
(3)1974 295/S
1975 340/S
carb slides
Jack,
Did you install the slides, lining up the guide pin with the groove cut in the side of the slides. Also, you may have guide the jet needle down into the needle jet as you install the slides.
- guitardude081
carb slides
It's in the groove. Everything goes right in until the spring, and slide are put together.
~Jack
~Jack
1983 Trailfire LX
(3)1974 295/S
1975 340/S
1983 Trailfire LX
(3)1974 295/S
1975 340/S
carb slides
Jack,
Here are a few things to try:
-loosen the cable adjusters
-remove the jet needle (it could be bent)
carb slides
Ck to see that the throttle cable isn't out of place at the throttle lever, sometimes they will pop out of the slot & will turn 1/4 turn in the throttle lever which keeps the throttle cable tighter than it should be.
Ken
Ken
- guitardude081
carb slides
The throttle lever is loose. It won't return all of the way. I'm going to putz with it after work.
~Jack
~Jack
1983 Trailfire LX
(3)1974 295/S
1975 340/S
1983 Trailfire LX
(3)1974 295/S
1975 340/S
