Kec 340 CCW engine questions
Metallica19991
Yo, i have a kec 340 ccw engine and i wanna know how i can test these parts to see if these work.. I am getting spark so the coils r good.. but does that mean all the condesners and point work as well? also.. theres a red and white wire coming out from underneath the flywheel. do i hook the coil that has the white wire up to the white wire? and the coil that has the red wire up to the red wire coming out from underneath the engine? which wire should be to what piston. cause right now i got the red wire coil to the PTO side piston and the white wire coil to the mag side. Is this right? cause i switch them before and i still cant get this damn thing started.. help would be app.. Thanks
Metallica19991m
If you are gettng a nice blue spark that can jump a 1/4 gap, the coils are good. We coverd the correct hook up of the red and white wires last night in chat. You could also have a carb problem or bad crank seals. Spray a small amount of premix into the carb throat and try and start it. I would also do a pressure test to determine if the crank seals are bad.
Did you ever check the compression?
Metallica19991
No i didn't check the compression.. but it seems as if it has good compression.. the piston rings have never been replaced ever.. and its been sitting for over 20 years. is that it?
problem solving a non-running engine involves a sytematic approuch.Metallica19991 wrote: No i didn't check the compression.. but it seems as if it has good compression.. the piston rings have never been replaced ever.. and its been sitting for over 20 years. is that it?
-Good Spark
-Fuel delivery(clean fuel filters, clean carb)
-Good compression ( over 100 psi )
-Good crank seals
Metallica19991
No i checked them there tight... umm it did pop.. but no backfire.. also gasoline comes out the exhaust.. is that good? if not how do i prevent this??
What did you check? Are the plugs wet after trying to start it.Metallica19991 wrote: No i checked them there tight... umm it did pop.. but no backfire.. also gasoline comes out the exhaust.. is that good? if not how do i prevent this??
Metallica19991
they are wet... but want i really want to know is why does fuel come out the exhaust manifold when i pull the engine over? its a reasonable amount of fuel too...
YOU HAVE IT FLOODED,,PULL YOUR PLUGS,PULL MOTOR OVER WITH PLUGS OUT THIS WILL DRY THE BORES OUT,DRY YOUR PLUGS,IF YOU CAN WIRE BRUSH THE ELECTRODE CLEAN ,CHECK YOUR END GAP,REINSTALL,OR NEWS PLUGS
75 800 440
79 TRAILFIRE 440
79 KAWI INVADER 440
06 SKI-DOO MACH Z 1000CC
79 TRAILFIRE 440
79 KAWI INVADER 440
I don't want to get too far ahead here...but if the flooding problem is chronic, if it keeps doing this, it may be that your carb is over fueling the engine.
Do you have a Walbro carb?
Does the pulse line from the side of the carb to the fitting on the crankcase have fuel in it? It shouldn't have more than a hint.
It's possible that the carb is the problem, but make sure the wires are hooked up correctly, and that you have good, consistant spark, and that the flooding persists before messing with the carb.
- HoosierDeereMan
- Real Name: Troy Miley
Since you have flooded the engine, it is also possible that you have fuel fouled the spark plugs. I would check all the things everyone has mentioned and try a new set of plugs as well.
Metallica19991
Ok. i bought new spark plugs and hooked them up.. then i switched the coils. IE red goes to PTO side, White goes to Mag side.. and she fired up real nice.. and well yeah it now works great. theres no backfire out of exhaust anymore.. but i was wondering what you guys would say the fuel ratio is? i have it 50:1 but i just dont think thats enough oil... the carb doesn't seem to flood the engine.. but i think it was the plugs.. they were over 25 years old.. im not surprised.. but yeah whats the fuel ratio? the engine is a kec 340 ccw engine (made in japan)
Well that was the first thing you should have done was change 20 YEAR OLD PLUGS. BOB
Metallica19991
well i mean this engine doesn't have more then 300 hours on it.. the rest of its life has been sitting on a self in a garage....
Do a Compression test to see if the seals have Dry rotted do to lack of oil on the shelf. BOB
