First question is simple:
1) What spark plugs do I need for 1979 trailfire 440?
Second Question:
I have 3 1976 Liquifire 440s 2 with square plug CDI and 1 with round plug.
Can these interchange or must you use the exact plug type?
I thought I read this somewhere on this site before but I couldn't find it last night!
Spark and CDI Question
Follow the wiring chart listed here to match the color code.
http://www.hewtechelectronics.com/images/FIREPLUG_WIRING.pdf
Thanks harleysportster that helps alot!!!!!
Still waiting for What spark plugs for a 79 trailfire?
The parts book states Champion N3, the NGK web site states BR8ES, R=resistor
Like Harley stated br8es or even 9s will work I run both at different times.
Thanks guys
Going riding tonight, 14 inches of white fluufy stuff, can't wait!
Remember WOT & only 30 MPH in deep snow conditions burns motors down, Once up to speed if you back way out of the throttle you'll find you can go just as fast & it's easier on the motor...
you must be getting old if you are telling someone to back out of the throttle
You of all people should know that if your running WOT & only doing a slow MPH that all those engine RPM's & no speed will do engine damage in time, But I'll have to assume that your post was your attempt at some sort of humor towards a poor old defenseless man.
