Spark and CDI Question
Liquifire76
Post by Liquifire76 »
First question is simple:
1) What spark plugs do I need for 1979 trailfire 440?
Second Question:
I have 3 1976 Liquifire 440s 2 with square plug CDI and 1 with round plug.
Can these interchange or must you use the exact plug type?
I thought I read this somewhere on this site before but I couldn't find it last night!
Yes you can.
Follow the wiring chart listed here to match the color code.
http://www.hewtechelectronics.com/images/FIREPLUG_WIRING.pdf
Liquifire76
Thanks harleysportster that helps alot!!!!!
Still waiting for What spark plugs for a 79 trailfire?
:D
The parts book states Champion N3, the NGK web site states BR8ES, R=resistor
JDFanPa
Post by JDFanPa »
Like Harley stated br8es or even 9s will work I run both at different times.
Liquifire76
:D Thanks guys
:D
Going riding tonight, 14 inches of white fluufy stuff, can't wait!
Remember WOT & only 30 MPH in deep snow conditions burns motors down, Once up to speed if you back way out of the throttle you'll find you can go just as fast & it's easier on the motor...
wadeo108
Post by wadeo108 »
you must be getting old if you are telling someone to back out of the throttle
You of all people should know that if your running WOT & only doing a slow MPH that all those engine RPM's & no speed will do engine damage in time, But I'll have to assume that your post was your attempt at some sort of humor towards a poor old defenseless man.
