81 lf problems
aleitheiser
81 lf problems
I was running down the ditch this morning about 50mph and the sled completely died, just like you turned off the key. It has spark and I plan to go through the carbs tonite. Any other suggestions wouild be helpful
carb setup
3.5 ca
6dh22 needle e clip third notch from bottom
P4 needle jet
35 pilot jet
150 mains
110/105 power jets
carb setup
3.5 ca
P4 needle jet
35 pilot jet
150 mains
110/105 power jets
tobeybacon
81 lf problems
did you pull the plugs and check the pistons through the holes. i had a sled do that to me twice it leaned itself out and burned a whole in the piston. it was the fuel pump. one side of the pump didnt work and the other did. dont know if this helps
81 lf problems
I think you should have cleaned your carbs last night??????
Mark.
aleitheiser
81 lf problems
I have cleand the carbs a couple of times, and no I have not pulled the plugs turning steel plugs out of warm aluminum heads is, at least for me, never a good thing. I do plan to check the pistons when I go pick up the sled. I thought of fuel pump problems also
adam
adam
aleitheiser
81 lf problems
Oh yippie, just pulled the plugs and lo and behold a hole in one of the pistons, next question is it easier to change tracks or engines. I have an 80 lf with a bad track and a good enigne.
adam
adam
81 lf problems
Personally I would swap a engine before a track. But if you go this route you still need to make sure both carbs are getting fuel. You may end up having problems with the good engine also just like this 1 if it sat along time it could fail a crankseal just as easy.
81 lf problems
Great all this talk of burning down right after I rebuilt mine.
BOB
81 lf problems
I think it's going to be a LLLLOOOOOOONNNNNNNGGGGGGG winter!
one down & it's only Dec. 4th
aleitheiser
81 lf problems
got a clutch puller coming and the transplant operation begins on saturday, along with a fuel pump kit to rebuild the pump
81 lf problems
If It goes I have decided to wait to put it back together And totally mod it. Port and Polish. Bore it out Shave the Heads Get the AAEN Pipes and re work everything. BOB
81 lf problems
Bob, I have a pair of new .080 over pistons!!!!! would that be bored out big enough for you???
81 lf problems
HA.
Bob do you have any idea how expensive that would be? It took you how long to get a tech manual cause you thought that was too much $$.
Are you being serious?
81 lf problems
Yes but not till I have a job and can afford it. I dont know all I can picture no is me going WOT across the Lake and it Blowing up. I just cant be sure I hope it is but We will have to see. BOB
- Danzig
- Real Name: Paul File
81 lf problems
I like this spill...
Like being a one legged man in a butt kicking contest!
81 lf problems
Come on I think it would be Fun even if I just had the Stingers and had it Bored out. BOB
