1976 Liquifire 440 Overheated
Deleted User
My friend recently loaned me his old 1976 liquifire 440 so that I could ride with others. It ran great all night, he informed me the motor was rebuilt a few years ago. However shortly before I got home it became really hot as snow became sparce. I shut it off and cooled it down, once I got it started again it ran terrible, I figured it was the plugs, I have replaced the plugs and it still runs terrible. It does not want to idle and when I hit the gas it bogs down. It also seems to be sputtering alot as well as backfiring. Can someone tell me what I did and how I can fix the problem? I would really appreciate it as I mentioned it is not mine. Thank you all for your advice.
Mustang,
Check the simple things first.:
spark in both cylinders
fouled plugs
clogged fuel filters
check compression
Reasons for overheating:
not enough snow coverage on ground(minimum should be 4 inches)
coolant level to low
broken or loose water pump belt
stuck thermostat(closed)
fouled plugs
check compression
grasscutter97
Compression test will be the first thing you need to try. That is usually a good tell!
- Danzig
- Real Name: Paul File
Is your friend big and mean? Lol........sorry for the bad luck, I am sure if you follow everyones suggestions you will find your answer to your problems.
Good Luck....
Good Luck....
