Cant find a CDi box
Cant find a CDi box
i have been looking for a CDI box for my 1976 340 liquifire. i looked on ebay and some other places and havent had any luck. i was wondering where is the best place to look next.
Cant find a CDi box
Are they worth the $145? i found ones of ebay that were new but for the 81 liquifires for $45.
Cant find a CDi box
I believe that I have one. Would like to know wire colors and connector style before I say for sure. Don
Cant find a CDi box
Don,
Here is the wiring coloring and crossover of A style, B style, and Hewtch cdi boxes.
http://www.hewtechelectronics.com/images/FIREPLUG_WIRING.pdf
Cant find a CDi box
Don, if i would tell you if it is an A-style ot B-style would that be enough. or do you need all the specific wire colors and the connectors like you said.
Cant find a CDi box
If it's a hewtech, then it will have a smallish box with two bundles of wires coming out of it..... And it will say Hewtech "FirePlug" CDI
If it's an original Prestolite, it will be a larger cubicle box with the wires coming out in a row and will say Prestolite on top.
Cant find a CDi box
Sorry, I think I confused everyone. What I have is an original Prestolite that came off of my Cyclone 440 #1. Only replaced it with a new one that looked nicer. This one has the wires for each coil, a 2 male/1female round connector, and a 1 male/1 female round connector. I'm pretty sure I replaced it with a new one from Cyclone Crazy aka Mn Vintage Snowmobile. Don
Cant find a CDi box
is a CDI box the same off of a Cyclone 440. my liquifire has two round connectors ones a three prong and the other is a two. so they sound the same. if they are the came CDI box, then i will take it Don.
Cant find a CDi box
JD part # AM54169, cdi box with round plugs is the same for both the cyclone and liquifire series engines. The 76 and early 77 series engines used a retangle plug, but you can splice the new round style cdi box to those applications.
Cant find a CDi box
Huston14 here's a deal for you. I just got a CDI box that has the wires cut off......duh. It could be used by wiring your ends on. You can have it free if you pay freight. Just need an address to get you a price. Don
Cant find a CDi box
I just bought a CDI for mine, it has a round end and I need square. What is the est way to do this (just use marrets) or what do you guys recomend.?
Cant find a CDi box
Follow this chart and match up the colors from the square plug tp the round. Cut wires of the old cdi box connector about 6 inches from the connector, splice the new cdi wires into those following the chart.S_Kyle wrote: I just bought a CDI for mine, it has a round end and I need square. What is the est way to do this (just use marrets) or what do you guys recomend.?
slide on srinkwrap before crimping butt connectors, then heat the srinkwrap over the connection.
