Aluminum engine parts cleaning
I'm starting on the restoration or my 74 300 and was wondering the best way to clean up aluminum parts on the motor. I'm completly disassembling the engine and rebuilding. Thanks,
Greg
Greg
- Liquifire84
I always start off with smiple green and a brush and warm water to start the cleaning process. Works great on rims and blocks on old cars to.
Brice
Brice
johndeere96
Hello
I read your post. Am in agreement with Simple Green and a scrub brush.
Here's another suggestion. I like a mixture of Tri Sodium Phosphate (TSP) car wash soap and water.
Soak the parts and scrub well with a nylon brush. Rinse well and polish with Autosol.
JohnDeere96
JohnDeere96
Metallica19991
I just use water, and likea wet old rag.. sand paper is really good at cleaning all the carbon off of the pistons. and its also good at getting those old stuck on gaskets off...
Metallica
Metallica
- flames4555
To to my first initial clean ups on the motor i use wd40 , a lot of rags and a scothbrite pad .It gives you a good indication of what youre dealing with and it will also cut the grease really well. I've got a collection small brushes that help get into all of the nooks and difficult areas.
Just put on some good music and clean away...
Kevin
76 cyclone 440 (dual carbs)
69 Arctic cat panther p22j
1982 kawasaki indtruder
1980 kawasaki 4/6
74 cheetah 440
1980 kawasaki 4/6
74 cheetah 440
- Danzig
- Real Name: Paul File
Beer and some Danzig or AC/DC and a can of nev-r-dull
- flames4555
I like to use Samuel Adams and a little Stevie Ray...
Kevin
1980 kawasaki 4/6
74 cheetah 440
1980 kawasaki 4/6
74 cheetah 440
Thanks guys, I'll give those ideas a try
nice thing about this motor is you can clean about 85% of it with a wire wheel in a drill Ive done 1 and its sitting on the shelf all nice and shiny.
If it ain't country, it ain't music.
That's right Don!
When you get past the grease and you are facing aluminum oxide (tarnish on aluminum) get a bottle of ETCHING mag cleaner and use per directions. Etching mag cleaner is an acid, and it does work very well.
Kenny Waters(boy)
Rochester, NY
'74 X-6
'75 X-8
'75 340S
'77 340 Liquifire
'78 440 Liquifire
'80 Spitfire
'82 Liquifire
'83 Liquifire
Rochester, NY
'74 X-6
'75 X-8
'75 340S
'77 340 Liquifire
'78 440 Liquifire
'80 Spitfire
'82 Liquifire
'83 Liquifire
- Danzig
spittttttttttttttttttttttttttttttttt-ding!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Hey ma................turn on the Conway Twitty in need a fix.
