rev limmiter
rev limmiter
How do I unhook the rev Limiter on these motors? do they even have limiters 76 440 23/lc 81kawi 440
rev limmiter
the 81 liquifire has a rev limiter, but its function is not to prevent overrev but it is a safety device intended to limit the engine rpm (approx 3200 rpm) and below clutch engagement speed in the event of a stuck or iced open slide. im not sure if you can unhook it but the throttle switch can be bypassed if it fails to work.
i am told that the kawasaki invader has a rev limiter to prevent overrev.
rev limmiter
mr deere said that it keeps it from going over 9000. would it blow if it was to go higher?
rev limmiter
On my Sportfire I was told to disconnect the single yellow wire coming out of the speed limiter that connects to a white wire if I had problems with it. With this disconnected it is not able to interfere with the ignition.
