i need some more help.
i got a salsbury primary clutch (i do believe it is the 9000 series) and it is sticking. i want to take it apart and clean it up and regrease it. the question i got is can i leave the clutch on the motor? how do you get the big 1-1/2"nut off? is there reverse threads anywhere? also what type of grease do i use?
does anybody know of any good tricks on how to get this clutch apart and what to watch for.
thanks in advance.
kuby
salsbury primary clutch help
oldslednut
Take it off, order a comet 94/c or 102/c the rollers inside your clutch are no doubt flatsided and junk, i dont know if i have ever seen a "good" used one, most were neglected and not lubed or cleaned and this is what happens
just my 2 pennies of thought !!!!
kuby
thanks for the input. you're not the only one that has said that.
question.
do you need a special puller to get that clutch off?
and will any comet clutch fit? how do i know if the shafts are the same? the engine is a ccw made by fugi. if i start looking on the internet. am i going to be looking at stuff that doesn't fit?
question.
Yes, you need a special tool to remove the clutch.
Call Central Snowmo, or DK and talk to them.
Rebuild parts may be available if you look around.
