What is the difference between the Walbro WDB-31 that is in the JD 300 Kohler and the Walbro WDA-32 on the JD 400 CCW?
I see a venturi on the WDA-32 but any other difference?
Will one provide better performance than the other?
And finally, any problem using the WDA-32 from the 400 CCW on the Kohler engine?
Howard
Walbro Wdb Vs Wda
DLDeere
- Real Name: Howard Olson
Walbro Wdb Vs Wda
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
The Hunter
Walbro Wdb Vs Wda
I have the exact same 2 carbs, I'm going to try and get the wdb-31 carb going with parts from the wda-32.
I imagine there would jetting differences between the 2 since they are different motors. I think your 300 would run stupid rich with the WDA-32 carb
DLDeere
Walbro Wdb Vs Wda
Hunter,
I've had the 300 running with the wda-32. Seems to be fine. I haven't had it on snow yet (we don't have any yet!) so it hasn't been on load, but I think it will be OK. I found out that the number is the size of the carb throat in millimeters. So the only difference in size is 1 mm. It fit fine on the 300 intake manifold.
I think the parts would be interchangeable, except the throttle and choke butterflies from the 32 may not fit into the 31.
Howard
Howard
DL Deere
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Walbro Wdb Vs Wda
Howard-
Wondering if you have any more info on using the WDA-32 on your 300?
Rodimus Prime
Walbro Wdb Vs Wda
venturi size is the biggest difference smaller engines 340 295 not a big performance gain. 400 - 440 go with the bigger opening to prevent starving. The walbro carb when working is actually a really good carb for trail running. wf carbs are a real pain but kinda neat in thier own way i have one somewhere.
The Hunter
Walbro Wdb Vs Wda
How well would a WDA-6 work on a 1977 Kolher 300?
