still haveing trouble with the liquifire
83BLACKJD
Post by 83BLACKJD »
i'am still haveing trouble with my (1983 440 liquifire) I think it is the seals. how do i test the seals to make shore. so i don't take my motor apart if i don't have to
:unsure:
guitardude081
Real Name: Jack Durand
Post by guitardude081 »
run the motor, and put soapy water on the carb flanges, and the oil seals. If the water bubbles, your seals are leaking. This also works for vacuum systems in cars as well.
~Jack
Owner, Durand Motorsports
1983 Trailfire LX
(3)1974 295/S
1975 340/S
deererunner
Post by deererunner »
Be a little more specific , What makes you think that it is seals ? When the seals are gone it`s really hard to get them going and when you do they want to rev faster than they should.. Deererunner....
83BLACKJD
Post by 83BLACKJD »
it starts real good when cold like one or two pulls. idles real good.and then when it gets warm it runs like s%@t 20 or 30 min's after start up.it will hardly pull it self .and won't idle then stalls then it takes 5 to 15 pulls to get it going . it does (not) rev at all even when warm. but untill it gets warm it runs like a top. it has new gas lines,filters,carbs are spotless.had them apart two or three times down to the last nut and bolt . and the air box is on it. new high test gas. gas tank is vented good .new spark plugs and wires .every thing works on this sled all lights
shelby
Post by shelby »
......Just for the hell of it....make sure your fuel pump is not backfeeding fuel into the crankcase, pull the vaccumn hose off and make sure its dry. I had a Rupp Nitro doing the same thing, started fine but ran worse as it got warmer......turned out that my fuel pump was the culprit......S
