It is a 1973 440 axle fan Kaw. This machine has been out side forever, some rust on steel parts. I am even having trouble getting the two halfs of the axle fan pulley off.
On the flywheel I have been using a steering wheel puller with grade 8 bolts and an elec. impact wrench, lots of heat and pen. oil. Won't budge. Any risk of riping the threads out of the flywheel? Could it be I am not getting enough torque out of the electric impact wrench?
PS This is an Arctic Cat engine, had it on "other brands" but no bites, sorry.
Getting off stuck flywheel
jerryswiss
big danno 1970
See my post "fan bearings" in this section MWKing had a good idea
jerryswiss
Yea thanks, I read that. I decided to just clean the points through the flywheel slots and go from there. It does run and the spark looked pretty good. I just wanted to change the points and condensors anyway. I am usually able to get the flywheels off, so this is a first for me.
