Anything I should know to make this easier... do they require any pre-wetting??
Found some old post (re: complete set of sprintfire decals for sale)
I still coud use right side tunnel and left and right side hood decals.
Dan
Installing decals
ChickenRat
Installing decals
I use the gallon of water and drop of soap trick. The Sprintfire hood should be straightforward as there are no curves on the hood like the Trailfire/Sportfire/Liquifire hoods. Those hoods are a bit trickier. However, just the opposite is true of the tunnels. The Snowfire/Sprintfires are very tricky because of the factory strength stampings in them. Essentially, the tunnels are wavy on the Snow/Sprint's. You'll need a heat gun and patience. The Trailfire/Sportfire/Liquifire tunnels are straight and thus very straightforward in applying decals to the tunnels of these sleds. Just make sure you work in a warm area and your tunnel/hood is clean before starting.
www.jdsleddecals.com should have the remaining decals you would need.
Robb
Robb
Installing decals
Thank you Robb,
Again these are the smaller hood decals (the ones that say "sprintfire").
I thought I remember reading using isopropyl alcohol... but from your post I gather they are peel and stick?
Thanks again.
Dan
Thanks again.
Dan
sledrescue
Installing decals
I either use warm water and a touch of dishwashing soap and wet up the area good with this. squeegee out from middle of the decal working outward. Frank at Engineered Graphics also sells a bottle of solution hat works very good for applying decals.
Jeff
Jeff
- flames4555
Installing decals
When I applied the decals to the cyclone I used a window tint installation kit I picked up at auto zone. Came with the solution and a nice soft squeege for working out any air bubbles.
Kevin
Kevin
Kevin
76 cyclone 440 (dual carbs)
69 Arctic cat panther p22j
1982 kawasaki indtruder
1980 kawasaki 4/6
74 cheetah 440
1980 kawasaki 4/6
74 cheetah 440
Installing decals
Sorry for returnig to this... never installed any decals.
These are for a hood. The decals seem to have a plastic (solid) backing which will peel away fairly easily. this leaves, however, what I presume is the back of the decal (only moderately tacky - BTW) but is still not "clear". Is there another layer that will come off with soap/water?? Based on my limit attempt (when dry) I cant get that cloudy layer (film?) to separate even at the corners.
Dan
Dan
