Recommended type drill bit
- johnnycyclone
- Real Name: Terre
I would like to install studs on my 77 liquifire. Any suggestions on the type of drill bit needed, to drill through the cleats? I tried a titanium coated one from the local hardware store, and managed only 2 holes before the bit became dull.
Thanks...Terre
Thanks...Terre
I think? you can get picks that will fit in the existing rivet holes. Drilling through the cleats will take a few bits to do.
moontreenrg
what kind of studs are you going to install? i have considered a scoop style stud myself. has anyone done this?
I used the "Scott Method". After trying to drill a couple with titanium, I took the track to Scott Henning. I found the job a lot easier by allowing Scott to drill the holes for me. May not work with everyone but it worked darn nice for me..............as my friend Kenny would say................that's my $0.00653467 worthjohnnycyclone wrote: Any suggestions on the type of drill bit needed
A cobalt drill bit will get you 10 holes or so before it needs to see the "Drill Doctor".
Turn it slowly with a fair amount of pressure, and it'll walk right through the cleat.
Carbide bits are very expensive & like Rich said turn very slow I would also maybe use some type of coolant.. I bought 2 Carbide bits for about $75.00 ea. years back ( late 70's ) & destroyed one in a very short time, I got it too hot & the carbide tip dropped off the end.. then we used cobalt bits, but like Brian says they are only good for about 10 holes..
Try a masonary drill bit! Carbide tip, seem to work the best, from my many years of drill ing cleats to put studs in them!
- johnnycyclone
- Real Name: Terre
S_kyle - That's a good idea, but I already have the studs, so I would like to use what I have.
moontreenrg - Woody's Gold Digger's - 5/16 x .875. And, yes from what I have read on here, they are a bit longer than recommended, but .750 are somewhat extinct. So we are going to go ahead and try the .875. I took a picture of what I am using, including a pic of one installed. It sticks out just under 1/2" from the cleat. I believe 3/8 is the maximum recommended from Woody's. So these are pretty close.
Don - If I had a someone like a Scott Henning, which I may have, if I look hard enough. I would certainly use him also.
Rich, Brian, and Kenny - Thanks for the tips, sounds like some great advice. I certainly would have thrown the bit in the drill, and gone after it on high speed. I'm sure you guys just saved me a few buck on drill bits.
sparcat - never thought of using a masonary bit. I will have to give that one a try.
Thanks for all of the responses....Terre
I just bought a couple of bags of .75 Gold Diggers from Central Snowmobile in the last month. But you are correct, Woody's has discontinued them.
Mean Green
Huh? Hasn't anyone read the Fine tune Manual? A cold chisel is the weapon of choice on this one, along with a BFH. ......Drill bits???
http://www.vintagesnow.com/John_Deere_files/JD%20Fine%20Tune.pdf
Page 45 for info. You're welcome.
Tracy
Tracy
Yes Tracy, you chisel off the rivet heads, pop the rivet out with a punch, then drill the cleat out to accept the stud.
I never had much luck with chiseling off the heads, so I cheat and use the grinder.
It is easy to drill out the cleat rivet. It is not easy to drill a new hole in a cleat. Pretty hard steel.
If I was going to drill 96 holes in cleats it I would remove the track and lay it on a drill press table.
- johnnycyclone
- Real Name: Terre
Just a quick follow up. I decided while at the auto parts store to ask about carbide drill bits, they didn't have any, but did have cobalt ones. Went ahead and purchased one to give it a try. Well it worked better than expected. I was able to drill all of the holes I needed, some where around 80 holes, without any problem. The bit did start to dull, near the end, but not enough to stop drilling. I kept the rpms down, used moderate pressure, letting the bit do the work, and didn't let the bit get to hot. Worked great!
Terre
Terre
cowboy mark
i just recently replaced about 1/2 of the cleats on my track, and i used the grinder to get the old ones off. that seemed to work well for me
Sleds owned..
1 1976 JD Cyclone
1 1976? JD Liquifire,
1 1977 JD Liquifire (parts)
1 1976 JD Cyclone
