Sportfire oil injection kit instruction
jdsnowfire
Post by jdsnowfire »
sportfire oil injection kit instructions. pg 1-2
jdsnowfire
jdsnowfire
jdsnowfire
jdsnowfire
jdsnowfire
JD600
Post by JD600 »
Could that kit be fitted on an earlier sled with a walbro carb? Say a JDX or 00 sled?
jdsnowfire
probably not
you whould have to modify nearly every part in it.
you whould have to modify your recoil to run the shaft through it- hardest part
find the correct oil pump for the volume of oil needed (ratio)- sport and trail pumps are different
drill and tap holes in the intake manifold for the injection nozzles
with machining experience it may be possible- i would not recomend it though
just wondering- has anyone actualy tried making a JDX/00 oil injected?
JD600
Post by JD600 »
Thanks. Just wondered if it was worth it or not. With the right tools, anything is possible, but not always worth it.
Thanks for posting that, I converted it to PDF:
http://www.jdsleds.com/articles/BM21200oilinjection.pdf
dmac601
Post by dmac601 »
I will buy the intake. Still lookin for one.
I've got dibs on a Sportfire oil pump if anyone finds one :)
