Sportfire oil injection kit instruction
jdsnowfire
sportfire oil injection kit instructions. pg 1-2
jdsnowfire
pg 3-4
jdsnowfire
pg 5-6
jdsnowfire
pg 7-8
jdsnowfire
jdsnowfire
Could that kit be fitted on an earlier sled with a walbro carb? Say a JDX or 00 sled?
Dustin Elder
Salem, OH
Salem, OH
jdsnowfire
probably not
you whould have to modify nearly every part in it.
you whould have to modify your recoil to run the shaft through it- hardest part
find the correct oil pump for the volume of oil needed (ratio)- sport and trail pumps are different
drill and tap holes in the intake manifold for the injection nozzles
with machining experience it may be possible- i would not recomend it though
just wondering- has anyone actualy tried making a JDX/00 oil injected?
Thanks. Just wondered if it was worth it or not. With the right tools, anything is possible, but not always worth it.
Dustin Elder
Salem, OH
Salem, OH
Thanks for posting that, I converted it to PDF:
http://www.jdsleds.com/articles/BM21200oilinjection.pdf
I will buy the intake. Still lookin for one.
I've got dibs on a Sportfire oil pump if anyone finds one
