81 TF440 crank bearing O rings
I was wondering where you guys get your crank bearing O rings? Are they something standard which can be found at a auto parts store or are they a special order. I am guessing they are metric. TA440A-D202 1981 trailfire. Help me out guys.
They should be the same as the old arctic cats that they used. Arcti cats used to use kawasaki engines. Central SNowmobile in green bay carries them. They are a 62 mm o ring. I would bet you could match them up at an auto parts store or a place like Motion Industries or any place that sells bearings if you have an old part number.
1988 & 1991 Polaris Indy 650s
Center Seal O Rings: Kawasaki pn# 92055-3002, Arctic Cat pn# 3001-437
You can get these at NAPA or your local auto parts store also.
Thank you guys!!
manitobatrailfires
The local shop got me o-rings from a mid-eighties ski doo 462.
1979 Trailfire 440, dad bought from Steinbach, MB JD dealership in 1980 with 1,200 mile and an aluminum tunnel on it, regular rider, 5,055 miles
1980 Trailfire 340, bought in 2008 with TA440A-C202 engine in it, regular rider, 6,250 miles, LF rubber track
1979 Trailfire 340, bought in 2009, in pieces and rough cosmetic shape, 440 cylinders ready to go in (need pistons still), no odometer
Are we talking about the two rubber o-rings one the crank between the weights? If so, how do you put those on? just slide them over the weights??
Joe
Joe
manitobatrailfires
That's all I did. Two for the seal in the middle, and a new one for each of the bearings in the middle. I was nervous that I was going to snap them but they all stretched over just fine.
Eric
Eric
Invader440
Helps if you soak them in hot water for a little bit before you put them on.
Re: 81 TF440 crank bearing O rings
NAPA part number 727-2035. Can't beat 88 cents!
