81 TF440 crank bearing O rings
monte44
Post by monte44 »
I was wondering where you guys get your crank bearing O rings? Are they something standard which can be found at a auto parts store or are they a special order. I am guessing they are metric. TA440A-D202 1981 trailfire. Help me out guys.
tmartin
Post by tmartin »
They should be the same as the old arctic cats that they used. Arcti cats used to use kawasaki engines. Central SNowmobile in green bay carries them. They are a 62 mm o ring. I would bet you could match them up at an auto parts store or a place like Motion Industries or any place that sells bearings if you have an old part number.
1988 & 1991 Polaris Indy 650s
Trucker
Post by Trucker »
Center Seal O Rings: Kawasaki pn# 92055-3002, Arctic Cat pn# 3001-437
You can get these at NAPA or your local auto parts store also.
monte44
Post by monte44 »
Thank you guys!!
manitobatrailfires
Post by manitobatrailfires »
The local shop got me o-rings from a mid-eighties ski doo 462.
flacker36
Post by flacker36 »
Are we talking about the two rubber o-rings one the crank between the weights? If so, how do you put those on? just slide them over the weights??
Joe
manitobatrailfires
That's all I did. Two for the seal in the middle, and a new one for each of the bearings in the middle. I was nervous that I was going to snap them but they all stretched over just fine.
Eric
Invader440
Post by Invader440 »
Helps if you soak them in hot water for a little bit before you put them on.
ps73526
Re: 81 TF440 crank bearing O rings
Post by ps73526 »
NAPA part number 727-2035. Can't beat 88 cents!
