Track goes by itself?
elachevr
Post by elachevr »
Hi,
I'm looking for ideas to prevent my 80 spitfire from taking off down the field by itself. It idles well when I first start it but after going for a ride, the track turns by itself. I need to hold the brake down so it won't go anywhere. The idling screw isn't pushing down the throttle. I've played with the needles for days without any success.
Your help would be appreciated.
Eric
Danzig
Real Name: Paul File
Post by Danzig »
Sounds like an air leak which is causing the high idle.
Are you sure the primary clutch is releasing during idle.
Sure you have the correct belt on it?
427cobra
Real Name: Eric
Post by 427cobra »
I would check to make sure the correct belt is being used and the clutches are adjusted correctly.
That Girl Racing
Real Name: Peter
Post by That Girl Racing »
demonic possession?
elachevr
Post by elachevr »
Thank for all the suggestions. I do believe it's possessed. That or it wants to run away because I won't keep it in the garage at night.
JD600
Post by JD600 »
My 600 did the same thing. Turns out, the old man is losin a little bit in his old age and ordered too short of a drive belt. Pretty simple fix. If it wants to run away to a new owner, i have a place for it in the shed :D
mikehjd
Post by mikehjd »
My 79 spitfire does the same thing. When you start it its good but after you ride it a bit it wants to creep. I hold the brake for a few seconds and let it sit and its fine, I'm thinking the clutch is a bit sticky.
JDFanPa
Post by JDFanPa »
lube the primary even if its just spraying some rust penatrant in on the weights etc I have a sled that I have to do this to every year
