1980 Liquifire
medicineman
1980 Liquifire
Post by medicineman »
Is there any performance gain if I remove the airbox from my 80 Liq 440 and follow with proper re jetting? Any suggested guidelines would be appreciated. The engine is stock.
wycrumb
1980 Liquifire
Post by wycrumb »
I knew this about the Liquifires but does it work the same on the Sportfire? Also does the rubber hose on the LF airbox need to be there to create the back pressure in the airbox?
Wycrumb
'82 Kawasaki KZ650 CSR
'74 John Deere 300
'72 John Deere 400
'73 John Deere 400
'73 John Deere 600
'80 John Deere Sportfire 440
That Girl Racing
Real Name: Peter
1980 Liquifire
Post by That Girl Racing »
I think the question is " if it was jetted right" . Air boxes calm down the incoming air and provide much more stable flow into the carbs. I doubt you would see any increase in power, maybe a slight decrease. Lets see how many people tell me I am wrong. Peter
medicineman
1980 Liquifire
medicineman wrote:Is there any performance gain if I remove the airbox from my 80 Liq 440 and follow with proper re jetting? Any suggested guidelines would be appreciated. The engine is stock.
re: the 1980 Liq., is there better driveability & perf. to be had on this machine if I install a different model of mikuni. I find the power jet carbs to be so touchy.
Thank you
Neil
guitardude081
Real Name: Jack Durand
1980 Liquifire
Post by guitardude081 »
Most people opt. for the 38mm non-PJs instead. You can then run K&N airfilters instead of the airbox. You'll have to hog some material out of the airbox "boots" if you choose to run the airbox. There are jetting guidelines in FAQs.
~Jack
Owner, Durand Motorsports
1983 Trailfire LX
(3)1974 295/S
1975 340/S
medicineman
1980 Liquifire
Thanks for the info Jack
Neil
