Restored JDX8
Restored JDX8
Completed restoration of a 1973 JDX8 (serial JDX8009382M). I am particularly happy with how the bogie suspension turned out. Thank you to all the members of this site that provided either parts or advise.
Pictures attached.
Pictures attached.
Restored JDX8
Beautiful x8. hope my x4 turns out half that nice.
T-Bone
T-Bone
Restored JDX8
WOW!!!!! I hope my 74 X6 and X8 turn out that nice!!! Where are you located?
Will
Will
1974 JDX6, 1974 JDX8
Restored JDX8
Thanks for the compliments.
I am located in Belleville WI which is south of Madison about 20 minutes. I would say from Burlington WI about 1.5 hour drive. I am always up for meeting with other JD nuts to talk sleds and such.
- Danzig
- Real Name: Paul File
Restored JDX8
- Real Name: Jerry Zebro
Restored JDX8
Excellent Job! Two thumbs up!
Jerry
Jerry
Restored JDX8
How do you guys get your fuel tanks to look like that?
Restored JDX8
Nice job on that sled. You should be proud.
Robb
Robb
Restored JDX8
Fuel tank question. First off start with a good fuel tank that is not all rusted and beat to hell. They are around enough that if you do not have a good one then go looking at a salvage yard. Make sure to check the inside too. The easy off and bolts takes care of the rust on the inside. On the outside I degrease it with engine cleaner, used WD40 and steel wool, about a 6 pack of beer and 3 hours in the shop just basically cleaning/sanding every inch of paint and rust. Then a coat of primer and then 1 light coat of I used high temp metalic grey paint. I am not an expert but I forsure learned that inorder to get good paint jobs you have to prime it, otherwise it will always turn out not as nice as it could have.
I thought about using the bead blaster but I was afraid it would be too rough but maybe not and it sure would have turned a 3 hour job into about 20 minutes. But also would have not got to drink the 6 pack as easily.
Restored JDX8
Wow, That is beautiful MATT. You aren't going to drive your restored "8" I hope
- I500
- Real Name: Chuck Moser
Restored JDX8
SWEEEEEEEEEEEEEEEEEEEEEEEEEEEEEET................Great job
